BreakPoint
Annual bug thread for 2025
Continued from the Year 2024 bug thread.
This thread serves as a repository of links to other discussions where newly discovered bugs are discussed.
The rules remain the same:
  • Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  • One post/bug!
  • One bug/post!
  • No discussion of bugs. All discussions of a bug must take place in the original linked thread.
Message 1 of 17
(2,528 Views)
Reentrant SubVI use can sometimes break the code.
Details here
Message 2 of 17
(2,526 Views)
Crash when undoing a TabControl replace
see: https://forums.ni.com/t5/LabVIEW/Crash-when-undoing-a-TabControl-replace/m-p/4426977
CAR #3030762
Message 3 of 17
(2,376 Views)
VI methods "Create from Data Type / Reference" clear undo history
See: https://forums.ni.com/t5/LabVIEW/Bug-VI-methods-quot-Create-from-Data-Type-Reference-quot-clear/m-p/...
BUG report number #3030762
Message 4 of 17
(2,374 Views)
Error Ring Bug with Enum Input
See: https://forums.ni.com/t5/LabVIEW/Error-Ring-Bug-with-Enum-Input/m-p/4299501
Bug Number 3036518
Message 5 of 17
(2,371 Views)
Crash when replacing a TabControl with "Replace No Attributes" method
See: https://forums.ni.com/t5/LabVIEW/Crash-when-replacing-a-TabControl-with-quot-Replace-No/m-p/4428123
Bug 3045969
Message 6 of 17
(2,308 Views)
VI unloads from subpanel and becomes corrupted when subpanel:InsertedVI property is called from asynchronous code, and that code goes out of memory
Reported here
Message 7 of 17
(2,010 Views)
Message 8 of 17
(1,469 Views)
@raphschru wrote:
Right-click menu "Help For ..." on property or invoke node crashes LabVIEW 2024 Q3
Bug #3178201 and #3182331
It works for me, but i've turned off the Online help ...
Qestit Systems
Certified-LabVIEW-Developer
Message 9 of 17
(1,453 Views)
Changing probe options while running can crash LabVIEW 2025 Q3
BUG 3441486
See: https://forums.ni.com/t5/LabVIEW/Changing-probe-options-while-running-can-crash-LabVIEW-2025-Q3/m-p/...
Message 10 of 17
(939 Views)
