User | Kudos |
17 | |
5 | |
4 | |
4 | |
4 |
Just to get this out of the way, this draws on the following ideas and integrates them into something that I think fits well with things like the web UI builder:
1 http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Case-Structure-Navigation/idi-p/1160707
2 http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Case-Structure-Controls/idi-p/1099942
3 http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Moveable-Case-Selector-Label/idi-p/1094982
4 http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Integrated-Structure-Labels/idi-p/936654
Basically, I think cases should have labels like in 4 (perhaps floating labels like I show below), but remove the other configuration items currently there. This eliminates the problem in 3, and essentially requires something like idea 2. Instead of the current selector, it will have a button similar to the tab viewer in IE (see picture), which will bring up a screen similar to idea #1. However, I think thumbnails arent enough, and I think it should show up more like this picture below:
Anyway, even if you don't like this idea, you should give kudos to the four above, because they are awesome.
Thanks!
Any idea that has received less than 4 kudos within 4 years after posting will be automatically declined.
