SteveChandler
Hide Control In Run Mode
Status: Completed
This feature is available in LabVIEW 2021 and later. Select Edit > Show Hidden Controls While Editing on the front panel to be able to see and edit hidden controls while the VI is in edit mode.
Many times I write a VI that is intended to run as a dialog. There are controls and indicators such as error in, error out and possibly class controls that I do not want to be visible when the dialog is running. What I usually do is to size the FP such that these are not visible to the user. I set the panel so that it can not be resized.
But that is not eating my own dogfood. What I have recently started doing is look at the Application.Kind property and hide controls in the runtime environment.
What about a new property to only hide controls when the VI is running? (Development system or runtime system). I don't want the controls hidden in edit mode because that makes it very difficult to wire the connector pane.
undefined
LabVIEW 2012
8 Comments
altenbach
Knight of NI
SteveChandler
Trusted Enthusiast
I do like both of those. The "ghosts" idea by tst would solve the same problem but you loose the ability to completely hide the control in edit mode. (although I don't understand why someone would want  a control hidden in edit mode)
LabVIEW 2012
AndyRR
I usually collect all controls that I want to hide to a TabControl. Thus I can make all hidden controls visible or hide them by a single property node. It can be very difficult to find all hidden controls if they have been hidden separately.
undefined
AristosQueue (NI)
NI Employee (retired)
Andy RR: Good idea. Useful work around.
Steve Chandler: Kudos.
Petru_Tarabuta
The Edit >> Show Hidden Controls While Editing option was added in recent versions of LabVIEW. This allows hiding GUI elements but still seeing them at edit-time. In effect, the GUI elements are hidden only when the VI is running. In my opinion this implements the feature identified by this idea, therefore the idea could be considered completed.
Darren
Proven Zealot
Status changed to: Completed
wiebe@CARYA
Knight of NI
Didn't notice this feature, it will serve me well...
Thanks @Petru_Tarabuta. The idea is closed, so I can't kudo your post...
