Community Browser
Post an idea
When drawing a selection rectangle that covers part of a cluster, structure, or wire, you can toggle selection of the entire thing by hitting the spacebar. (https://www.ni.com/docs/en-US/bundle/labview/page/selecting-objects.html)
I propose the same functionality with arrays. It's odd to me that this handy feature works with clusters and not arrays.
Current Behavior of LabVIEW
Currently, the error messages that emerge from bad call to a Property Node or Invoke Node only state that the error occurred in a property node or invoke node.
User Need
As a user of LabVIEW, it saves me considerable time in development/debugging, when I can precisely know why and where in the code an error occurred , so that I can get on with the actual work of fixing the bug in my own code/logic.
Problem For Users
The current behavior, described above, makes it impossible to know (without placing probes and retaining wire values):
A) Which Property Node or Invoke Node actually generated the error (in cases where there are many of such nodes)? Again, all we know is that some Property/Invoke Node on the block diagram of the VI raised the error.
B) Which specific Property actually caused the error, in cases where a Property Node has multiple properties that it is reading and/or writing.  Again, all we know is that the error occurred inside a Property Node.
Proposed Solution
Error message for invoke/property nodes should state:
- the Name of the Method or Property where the error occurred
- the Class Name of the VI Server Object (if available)
- the Object Refnum value (e.g. the hex value of the object reference)
- possibly even (only if running in the editor and not the runtime environment) the VI Server Scripting UID of the GObject node on the Block Diagram for super-fast debugging with a "fancy error dialog of the future" (TM) whose LV Idea Exchange post with undoubtedly be coming soon...
I work with PPLs quite a bit...and sometimes...I just want to rename them.
Libraries that depend on the renamed PPL will then be broken, as expected.  Example here:
It would be awesome if I could simply go in, right-click on the missing dependency, and replace it with the newly named one. But...for whatever reason...this option is disabled.  Instead, I find myself having to go in and manually replace each individual broken PPL call (VIs, typedefs, etc.). This is unnecessarily time consuming and error prone.
Especially when I use setting windows I normally transfer the actual settings from a setting-cluster or from global variables to multiple local variables and display the current settings in the front panel. After the user edited the settings of course the settings need to be transferred again to global variables or in a setting-cluster. So if multiple global or local variables are used, each variable need to be changed from read to write 1 by 1 by right click and selecting the action from the menu.
So I suggest to implement a function to change it at the same time for all marked variables, similar to property nodes.
The suggested procedure would be:
  • Mark variables with the mouse by holding "Shift" on the keyboard or drawing a frame
  • Right click to context menue
  • Change all to read / write
The feature would be consistent, because it is for example possible to create local variables of multiple controls at once with a similar procedure. (I just don't get in mind why the order is always upside down when I do this)
When you're looking at the front panel of non-editable VIs, such as VIs in PPLs, many options aren't available. Some of these are still applicable, and would be really useful.
Example 1: If I want to go look at a class definition, normally I could right-click on the class in a front panel and then choose "Show Class Library".  However, it isn't available if the VI is locked. My (less-than-ideal) workaround is to "Copy Data", drop the class on a new block diagram, and then I have access to all the normal menu options.
Example 2: The connector pane isn't visible. I often want to look at what is wired where on the connector pane, or to check if inputs are dynamic, but this info isn't visible.
We know that LabVIEW has some magic that it uses for automatic error handling.  What if LabVIEW could use such sorcery to enrich the error string flowing on the wire, with information about the originating source of the error -- specifically the VI Reference and GObject UID of the node where the error was introduced.  Then a "fancy error dialog of the future" (TM) could utilize those UIDs to navigate directly to the node and highlight it (a visual effect to show which node it is). This behavior could be added to the Simple Error Handler and General Error Handler VIs, and maybe ever there could be a "LabVIEW Gems" vi.lib utility that can extract the VI Reference and GObject UID for use in other, 3rd party tools.
I often use the "Find All Instances" option from the right-click menu when clicking on a VI's icon to find all callers of that VI. However, it regularly comes up with fewer hits than the "Find Callers" option. In this case, it came up with 0 hits:
However, if I navigate to the VI in my project (ctrl+shift+e) and then right-click on it and select "Find -> Callers" it will actually find the callers:
I've never understood this discrepancy, and I see it regularly. Perhaps this is more a bug than a feature request -- but I do feel that if these callers are consistently findable from through one of these mechanisms, they should be consistently findable through both.
Note: in the case above, if I do open the VI (after finding in using "Find Callers"), it will then be found if I "Find All Instances...".  But if I close the VI, it's no longer found using "Find All Instances".
Problem
I find myself wanting to Ctrl+Drag to add/remove diagram space INSIDE of a structure without actually resizing the structure itself AND without modifying any other frames – I just want to clean up the visible diagram that I am working on.
However, this is not how LabVIEW currently works – the structure itself is also resized, and the space within other frames of the structure are resized as well (outward/inward from the same point as the Ctrl+Drag action), which can mess up both the code in other frames as well as the code outside the structure.
Proposed Solutions
Option 1: Lock Structure Size Add the ability to lock the size of structures (or perhaps only lock them from growing during creating/removing space), so that I can use Ctrl+Drag to create/remove space without impacting the structure and the code around it. This would be similar to "Auto Grow" but would perhaps be an "Allow Grow" or "Lock Size" setting.
Option 2: Modifier Key Use the Shift modifier during Ctrl+Drag and Ctrl+Alt+Drag to NOT resize the containing structure. This would maintain backward compatibility while adding the new functionality.
Why This Matters
When working on complex VIs with multiple frames in structures, it's frustrating to have simple diagram space cleanup operations affect the entire structure and surrounding code. This feature would allow developers to better organize/tidy the code within individual frames without the ripple effect of resizing everything (in other frames and outside the structure).
Starting from LV 2023 Q1, the terminals height of some nodes was harmonized to 16 pixels to improve diagram readability by reducing the amount of needed wire bends.
Some candidates for this harmonization were omitted though:
 - Data nodes of timed structures (timed loop, timed sequence).
 - I think pretty much all of FPGA nodes (IO nodes / methods / properties, FIFO / memory / register / handshake methods, IP integration, high-troughput math nodes, ...).
Example with a Timed Loop:
The idea is to also allow RT and FPGA developments to benefit from this harmonization.
Currently, new sublasses require the user to find the correct parent class in the class tree. In larger projects, this can be really painfull.
I suggest two simple things to improve this very common task:
1. Make the class tree searchable: Put a filter string input above where you can filter the tree by name
2. Add a "Create New Sub-Class from this Class" Item to the context menu in project explorer. This could simpy open the class tree with the matching class already selected. Something like this would also be great for interfaces.
What is a strictly-typed reference?
A strictly-typed reference is a kind of reference whose type descriptor contains an inner, user-specified data type.
For example, a queue is a strictly-typed reference because it contains the data type for its elements, specified when creating the queue.
Here is a non-exhaustive list of such reference types:
 - Queue
 - Notifier
 - User event
 - DVR
 - Datalog file reference
 - Strictly-typed control refnum
 - Strictly-typed VI refnum
 - Shared variable
 - Network stream (reader/writer)
 - RT FIFO
 - FPGA IO / register / memory / FIFO / handshake
Idea:
Add a new primitive that would output the inner data type of any strictly-typed reference.
Here is a design example of the primitive, which could be named "Get Contained Data Type of Strictly-Typed Reference":
It would work for all the strictly-typed references mentioned above.
Motivations:
The implementation of malleable VIs is sometimes limited (or made complicated) by the fact that we miss some basic "type operators", such as getting the contained data type of a strictly-typed reference. While this missing function could be implemented using some tricks for most strictly-typed reference types, it is for example impossible for user events (See this thread for more details).
Typical application:
A malleable VI that takes a user event (for its type) and outputs a newly created refnum with the same contained data type:
This simple code is currently impossible in the general case due to the nature of user events.
Remarks:
1. The output terminal of this primitive will have to be named exactly as the contained data type, which is crucial for user events.
2. The output would have the LabVIEW default value for the data type (False for booleans, 0 for numerics, "" for strings, ...).
3. The primitive could be placed in a dedicated "Malleable VI Tools" palette.
4. In case the FPGA-specific implementation creates a dependency to the FPGA module, we could have a separate primitive just for FPGA (and also for RT if required).
What do you think?
Raphaël.
I want to be able to programmatically change the color of the LEDs on push buttons.
The colors[4] property will change the color of the housing, but not the LED itself.
This push button is one of the controls that is both a control and an indicator rolled into one.
In my particular case, I want to represent a third state. I have a valve that can be open, closed, or in transit.
There are two actuation states of open and close, but three indicator states.
I think making it a property I can control is a powerful solution. Not only will it solve my use case, but I can have all different colors of Booleans without needing to use Customize Control and the Control Editor to modify the colors.
Extra credit request: Can we make just the LED blink?  Right now, the blinking property blinks the entire control, but wouldn't it be cool if just the LED blinked? This is what those same two controls look like when blinking:
Maybe it's a new property just for LEDs that's separate from "Blinking". I'd be okay with that if you want to preserve current behavior.
Here are some related Idea Exchange posts related to a tri-state Boolean. They're not quite what I want, but I thought I'd link to them for reference:
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Tri-State-Boolean/idi-p/1139952
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Special-LED-control-with-three-states-Default-ON-OFF/idi-p/991307
It is necessary for porting code that uses several functions in C or Python(or other languages) to LabVIEW's Formula Node.
A very common task when operating with 2D pictures are mouse down/move events where we are interested which pixel was just clicked. While there is an event data node for the clicked coordinates these are relative to the front panel and translating them into image pixel coordinates is a chore and requires jumping through flaming hoops tweaks. (i.e. label yes/no? zoom factor? etc.)
However, there is a "Mouse" property for 2D images that has all the information directly in pixel coordinates and mouse button states. Currently, we need to read that property inside the mouse event to easily get the information we always (always!!!) want in such an event!
It would be cleaner if mouse events on pictures would output these mouse properties directly as an additional event data node.
Two clear advantages:
  • Cleaner code for those who know how to work with this property.
  • Stop sending newbies on a snipe hunt trying to figure out how to translate the current "coords" event data node into something useful for the intended task.
Here is an example where this idea would have helped
Here's a picture for the graphical thinkers!
Thanks for voting!
It would be nice to get 64bit references. The old 32bit references are build up from two main parts: the descriptor represented on 12bits and the address represented on 20bits. If the application requires more than the available 1048576 references the labview generates an error because the memory is full. The workaround is to close references found in the memory. If an application requires serialization, this rule should be kept in mind. If the application serializes references by an input data, the input data should be limited, which means that really big data can't be handled although the machine have enough memory to handle them. Unfortunately, this feature in the labview has been not changed in the last 30 years although 64bit processor architectures are used world-wide and the 64bit labview plays a bigger role every year.
I think, the main reason is the backward compatibility...but is it possible to provide 64bit references which could be chosen by the developer itself, where the descriptor field will not be changed but additional 32bits are available for addressing? e.g. new option in the labview settings "use 64bit references" or selection (polymorphic) from all native components which could be create a reference. If the feature is supported by (environment) settings, then the compiler uses it generic. If the feature is supported component level, then the references should be checked for conflicts. At the end the architect/developer/application is no more limited inside in the labview because the available 4503599627370496 addresses are more than enough for a long time again.
The Desktop Execution Trace Toolkit (DETT) collects hundreds to thousands of data points that indicate memory allocations, queue references, events, and more.  The data is always available and often is overwhelming.  The only way to make sense of data quickly is to create custom probes that create highlights in the data, however, that is only after you know which VI is worth probing further.
The idea:
Feed all the data normally collected by the DETT about a LabVIEW project directly into Nigel so that it can provide human-friendly suggestions explaining:
Level 1
How often a VI allocates memory in a repeated fashion
The time jitter between different events
VI's that could be good candidates for refactoring
Level 2
Improvements to the code within that VI based on best practices for optimal compiler operations.
This is based off a discussion at GDevCon #6 on September 10th, 2025.
The zooming feature in LabVIEW was way past due, particularly with the advent of 4k displays (and the rapid degradation of my sight!), but was implemented very poorly.   As mentioned in other idea exchanges, the font size handling is awful, and regardless does not address the ancient-looking pixelated block diagram interface.   Also the zoom resolution has too many steps for how drastically the view contorts with each step.
The entire system should be overhauled as vector-based so it looks crisp at any zoom level and zooms smoothly between zoom levels.   The shining light example of smooth-zooming is Miro which handles text sizes and detail-loading even better than Google Maps.
I am really looking forward to not squinting at pixels, and LabVIEW is literally the last offender I work with.
It is necessary for porting code that uses nextafter() in C or Python(or other languages) to LabVIEW.
Hi all,
I' normally using one or multipe queued message handler with a clustered enum (which is saved as Type Def.) and a variant as a basic architecture of my programs. This makes sense and it is relatively easy to search forward and check a program step by step. Unfortunately, it is not so easy to go stepwise back in the program for debugging., especially if there are multiple callers of a function.
Therefore I wish I have a function, where I can search for a single item of this enum Type Def.
I know that there is a possibility to search a text and of course it will find these items, but is also finds all other kind of things labeled the same.
I had a small chat with a engineer of NI already and we had an idea to gerneralize this a little to give it more use cases.
In the current situation, we can search for a:
- Type Def. , but then it will find each item of the enum OR
- text, but then it will find all items labeled with this text.
So here is our idea:
Create a possibility in the search window to combine these 2 search formats with a boolean operator, in our special case, this would be AND. But in other cases it might be also useful to have some other operators.
You are welcome to share any thoughts about it.
Best Regards, Patrick
The new debug window in LabVIEW 2025 Q3 automatically expands arrays to show all elements across multiple lines. While this full view can be helpful, it often becomes disruptive during debugging.
I have attached a video that shows a side-by-side comparison. The left side is LabVIEW 2025 Q3, and the right side is LabVIEW 2024 Q3.
As you can see, when an array contains many elements, the new multi-line display consumes a large amount of vertical space on the block diagram. This pushes other probes and data displays down, causing their positions to shift and making it difficult to monitor them. There are many cases where I only need to see that the array contains data, not every single element, and I would prefer the more compact, single-line view.
I propose adding a feature to allow users to select the display mode for arrays in the debug window. It would be ideal to have a toggle or option to switch between the new multi-line view and the classic single-line view, similar to how it worked in LabVIEW 2024 Q3 and older versions.
This would provide the flexibility to choose the most appropriate view for the situation, greatly improving the debugging workflow and the visibility of other data on the diagram.
