Community Browser
Top Authors
Post an idea
In previous versions of LabVIEW (including 25Q1), if you right-clicked on a wire, you could navigate directly to the Breakpoint Manager. With the merging of probes and breakpoints in 25Q3, the "Breakpoint Manager" has been replaced with the "Debug Window".  However -- there's no longer a right-click shortcut on wires to navigate to it.  I'd like to see this brought back, as it's a more intuitive location to find it than the View menu. Finding it for the first time after the switch wasn't obvious either, because of the name change.
(And yes, I'm aware that there's now a keyboard shortcut to directly access the Debug Window (ctrl+d) which I'll be using in the future, but I wouldn't expect most users to have this memorized.)
DVRs are extremely powerful, yet tedious to work with. Much of the coding is just a matter of following the exact same pattern over and over again, while making the code uglier. And I have yet to come up with a good way to reduce that coding overhead...
What if there was a built-in DVR call wrapper that allowed direct access to VIs?
The UI experience could be a hybrid of the Static VI Reference and Call by Reference functions: drop the "DVR Call Wrapper" on the block diagram, drag your VI into it, then wire it up directly.
It could have options for write and read-only.  And it could have right-click options for changing default error behavior.
My standard use case would be class calls specifically, but I don't see a reason this couldn't be applied to any data type -- although some serious thought would have to go into expected behavior in terms of which terminal to treat as the DVR (although this could be dynamic based on which terminal a DVR is wired into, or maybe even settable on the wrapper).
A tool like this would likely save me countless hours of development time, and make it less likely that I'd make coding mistakes while writing routine code.
Proposing adding right-click menu option for bundle and unbundle cluster elements, which allows the user to rearrange the order of elements with wiring automatically updated.  This is a frequent and tedious task when cleaning block diagrams that currently involves many steps and introduces risk of mis-wiring - this change would leverage existing behaviors to reduce time spent cleaning block diagrams.
Current Behavior of LabVIEW
Currently, the error messages that emerge from bad call to a Property Node or Invoke Node only state that the error occurred in a property node or invoke node.
User Need
As a user of LabVIEW, it saves me considerable time in development/debugging, when I can precisely know why and where in the code an error occurred , so that I can get on with the actual work of fixing the bug in my own code/logic.
Problem For Users
The current behavior, described above, makes it impossible to know (without placing probes and retaining wire values):
A) Which Property Node or Invoke Node actually generated the error (in cases where there are many of such nodes)? Again, all we know is that some Property/Invoke Node on the block diagram of the VI raised the error.
B) Which specific Property actually caused the error, in cases where a Property Node has multiple properties that it is reading and/or writing.  Again, all we know is that the error occurred inside a Property Node.
Proposed Solution
Error message for invoke/property nodes should state:
- the Name of the Method or Property where the error occurred
- the Class Name of the VI Server Object (if available)
- the Object Refnum value (e.g. the hex value of the object reference)
- possibly even (only if running in the editor and not the runtime environment) the VI Server Scripting UID of the GObject node on the Block Diagram for super-fast debugging with a "fancy error dialog of the future" (TM) whose LV Idea Exchange post with undoubtedly be coming soon...
Problem
I find myself wanting to Ctrl+Drag to add/remove diagram space INSIDE of a structure without actually resizing the structure itself AND without modifying any other frames – I just want to clean up the visible diagram that I am working on.
However, this is not how LabVIEW currently works – the structure itself is also resized, and the space within other frames of the structure are resized as well (outward/inward from the same point as the Ctrl+Drag action), which can mess up both the code in other frames as well as the code outside the structure.
Proposed Solutions
Option 1: Lock Structure Size Add the ability to lock the size of structures (or perhaps only lock them from growing during creating/removing space), so that I can use Ctrl+Drag to create/remove space without impacting the structure and the code around it. This would be similar to "Auto Grow" but would perhaps be an "Allow Grow" or "Lock Size" setting.
Option 2: Modifier Key Use the Shift modifier during Ctrl+Drag and Ctrl+Alt+Drag to NOT resize the containing structure. This would maintain backward compatibility while adding the new functionality.
Why This Matters
When working on complex VIs with multiple frames in structures, it's frustrating to have simple diagram space cleanup operations affect the entire structure and surrounding code. This feature would allow developers to better organize/tidy the code within individual frames without the ripple effect of resizing everything (in other frames and outside the structure).
Existing right click menu during wiring provides options to create terminals or wire branches.   Proposing a feature to add a cluster unbundle terminal when wiring clusters, that places and wires the terminal with the desired element reference.
I work with PPLs quite a bit...and sometimes...I just want to rename them.
Libraries that depend on the renamed PPL will then be broken, as expected.  Example here:
It would be awesome if I could simply go in, right-click on the missing dependency, and replace it with the newly named one. But...for whatever reason...this option is disabled.  Instead, I find myself having to go in and manually replace each individual broken PPL call (VIs, typedefs, etc.). This is unnecessarily time consuming and error prone.
We know that LabVIEW has some magic that it uses for automatic error handling.  What if LabVIEW could use such sorcery to enrich the error string flowing on the wire, with information about the originating source of the error -- specifically the VI Reference and GObject UID of the node where the error was introduced.  Then a "fancy error dialog of the future" (TM) could utilize those UIDs to navigate directly to the node and highlight it (a visual effect to show which node it is). This behavior could be added to the Simple Error Handler and General Error Handler VIs, and maybe ever there could be a "LabVIEW Gems" vi.lib utility that can extract the VI Reference and GObject UID for use in other, 3rd party tools.
Especially when I use setting windows I normally transfer the actual settings from a setting-cluster or from global variables to multiple local variables and display the current settings in the front panel. After the user edited the settings of course the settings need to be transferred again to global variables or in a setting-cluster. So if multiple global or local variables are used, each variable need to be changed from read to write 1 by 1 by right click and selecting the action from the menu.
So I suggest to implement a function to change it at the same time for all marked variables, similar to property nodes.
The suggested procedure would be:
  • Mark variables with the mouse by holding "Shift" on the keyboard or drawing a frame
  • Right click to context menue
  • Change all to read / write
The feature would be consistent, because it is for example possible to create local variables of multiple controls at once with a similar procedure. (I just don't get in mind why the order is always upside down when I do this)
I quite often find myself wanting to change the look and feel of front panels items. You currently have to do one at a time. Would be great to be able to highlight all of the Booleans and change what they look like in one go ( Similar to how we can change the size of other properties).
Surrounding structures should not grow while I´m typing in a string constant or comment.
Only afterwards when I move or resize the string constant or comment.
Starting from LV 2023 Q1, the terminals height of some nodes was harmonized to 16 pixels to improve diagram readability by reducing the amount of needed wire bends.
Some candidates for this harmonization were omitted though:
 - Data nodes of timed structures (timed loop, timed sequence).
 - I think pretty much all of FPGA nodes (IO nodes / methods / properties, FIFO / memory / register / handshake methods, IP integration, high-troughput math nodes, ...).
Example with a Timed Loop:
The idea is to also allow RT and FPGA developments to benefit from this harmonization.
When you're looking at the front panel of non-editable VIs, such as VIs in PPLs, many options aren't available. Some of these are still applicable, and would be really useful.
Example 1: If I want to go look at a class definition, normally I could right-click on the class in a front panel and then choose "Show Class Library".  However, it isn't available if the VI is locked. My (less-than-ideal) workaround is to "Copy Data", drop the class on a new block diagram, and then I have access to all the normal menu options.
Example 2: The connector pane isn't visible. I often want to look at what is wired where on the connector pane, or to check if inputs are dynamic, but this info isn't visible.
When drawing a selection rectangle that covers part of a cluster, structure, or wire, you can toggle selection of the entire thing by hitting the spacebar. (https://www.ni.com/docs/en-US/bundle/labview/page/selecting-objects.html)
I propose the same functionality with arrays. It's odd to me that this handy feature works with clusters and not arrays.
What is a strictly-typed reference?
A strictly-typed reference is a kind of reference whose type descriptor contains an inner, user-specified data type.
For example, a queue is a strictly-typed reference because it contains the data type for its elements, specified when creating the queue.
Here is a non-exhaustive list of such reference types:
 - Queue
 - Notifier
 - User event
 - DVR
 - Datalog file reference
 - Strictly-typed control refnum
 - Strictly-typed VI refnum
 - Shared variable
 - Network stream (reader/writer)
 - RT FIFO
 - FPGA IO / register / memory / FIFO / handshake
Idea:
Add a new primitive that would output the inner data type of any strictly-typed reference.
Here is a design example of the primitive, which could be named "Get Contained Data Type of Strictly-Typed Reference":
It would work for all the strictly-typed references mentioned above.
Motivations:
The implementation of malleable VIs is sometimes limited (or made complicated) by the fact that we miss some basic "type operators", such as getting the contained data type of a strictly-typed reference. While this missing function could be implemented using some tricks for most strictly-typed reference types, it is for example impossible for user events (See this thread for more details).
Typical application:
A malleable VI that takes a user event (for its type) and outputs a newly created refnum with the same contained data type:
This simple code is currently impossible in the general case due to the nature of user events.
Remarks:
1. The output terminal of this primitive will have to be named exactly as the contained data type, which is crucial for user events.
2. The output would have the LabVIEW default value for the data type (False for booleans, 0 for numerics, "" for strings, ...).
3. The primitive could be placed in a dedicated "Malleable VI Tools" palette.
4. In case the FPGA-specific implementation creates a dependency to the FPGA module, we could have a separate primitive just for FPGA (and also for RT if required).
What do you think?
Raphaël.
I often use the "Find All Instances" option from the right-click menu when clicking on a VI's icon to find all callers of that VI. However, it regularly comes up with fewer hits than the "Find Callers" option. In this case, it came up with 0 hits:
However, if I navigate to the VI in my project (ctrl+shift+e) and then right-click on it and select "Find -> Callers" it will actually find the callers:
I've never understood this discrepancy, and I see it regularly. Perhaps this is more a bug than a feature request -- but I do feel that if these callers are consistently findable from through one of these mechanisms, they should be consistently findable through both.
Note: in the case above, if I do open the VI (after finding in using "Find Callers"), it will then be found if I "Find All Instances...".  But if I close the VI, it's no longer found using "Find All Instances".
I want to be able to programmatically change the color of the LEDs on push buttons.
The colors[4] property will change the color of the housing, but not the LED itself.
This push button is one of the controls that is both a control and an indicator rolled into one.
In my particular case, I want to represent a third state. I have a valve that can be open, closed, or in transit.
There are two actuation states of open and close, but three indicator states.
I think making it a property I can control is a powerful solution. Not only will it solve my use case, but I can have all different colors of Booleans without needing to use Customize Control and the Control Editor to modify the colors.
Extra credit request: Can we make just the LED blink?  Right now, the blinking property blinks the entire control, but wouldn't it be cool if just the LED blinked? This is what those same two controls look like when blinking:
Maybe it's a new property just for LEDs that's separate from "Blinking". I'd be okay with that if you want to preserve current behavior.
Here are some related Idea Exchange posts related to a tri-state Boolean. They're not quite what I want, but I thought I'd link to them for reference:
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Tri-State-Boolean/idi-p/1139952
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Special-LED-control-with-three-states-Default-ON-OFF/idi-p/991307
A very common task when operating with 2D pictures are mouse down/move events where we are interested which pixel was just clicked. While there is an event data node for the clicked coordinates these are relative to the front panel and translating them into image pixel coordinates is a chore and requires jumping through flaming hoops tweaks. (i.e. label yes/no? zoom factor? etc.)
However, there is a "Mouse" property for 2D images that has all the information directly in pixel coordinates and mouse button states. Currently, we need to read that property inside the mouse event to easily get the information we always (always!!!) want in such an event!
It would be cleaner if mouse events on pictures would output these mouse properties directly as an additional event data node.
Two clear advantages:
  • Cleaner code for those who know how to work with this property.
  • Stop sending newbies on a snipe hunt trying to figure out how to translate the current "coords" event data node into something useful for the intended task.
Here is an example where this idea would have helped
Here's a picture for the graphical thinkers!
Thanks for voting!
Currently, new sublasses require the user to find the correct parent class in the class tree. In larger projects, this can be really painfull.
I suggest two simple things to improve this very common task:
1. Make the class tree searchable: Put a filter string input above where you can filter the tree by name
2. Add a "Create New Sub-Class from this Class" Item to the context menu in project explorer. This could simpy open the class tree with the matching class already selected. Something like this would also be great for interfaces.
Make Nigel AI advisor able to analyze changes within git repo and suggest a commit message.
This would be useful to :
  • Make commit messages more relevant / use message conventions
  • Avoid undesired changes
  • Avoid undocumented changes
