Use relative paths or project items for custom test bench VIs
Announcements
The NI Idea Exchange is a product feedback forum where NI R&D and users work together to submit ideas, collaborate on their development, and vote for the ones they like best. View all of the NI Idea Exchanges to post an idea or add your opinion on an existing one today!
When setting up a custom VI to use as a simulation test bench, you are currently limited to setting a constant path. If you move your VI, send it to another user, change the name, or otherwise change the path of the custom VI, you must enter the FPGA target settings and modify the path. That is, if you moved the project below from user1's desktop to user2's desktop, you would have to enter the properties and change the location. This makes code sharing somewhat tedious.
Using a relative path or a project item would make this feature easier to use.
You must be a registered user to add a comment here. If you've already registered, please log in. If you haven't registered yet, please register and log in.
Does your idea apply to LabVIEW in general? Get the best feedback by posting it on the original LabVIEW Idea Exchange.
Browse by label or search in the LabVIEW FPGA Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
If your idea has not been submitted click New Idea to submit a product idea to the LabVIEW FPGA Idea Exchange. Be sure to submit a separate post for each idea.
Watch as the community gives your idea kudos and adds their input.
As NI R&D considers the idea, they will change the idea status.
Give kudos to other ideas that you would like to see in a future version of LabVIEW FPGA!
