VeriStand
veristand UDP buffer size?
what determines how much data Veristand is going to send when subscribing to Veristand channels using Veristand .net.
I would expect it to be a setting or a rule based on the project.  i am seeing new data every 66 ms.  would like that to be longer.
there is a max_packet_size property returned from IUDPChannelStreamSession.  should that value be routed to the UDP read?  or any higher number would be good too?
Thanks.
Stu
(590 Views)
Accepted by topic author srm@viewpointusa.com
See Solved: Default Execution Rate 15Hz of Communication Send Loop
https://tmesystems.net/
(576 Views)
thank you.
it is frustrating that searching did not find this solution.
much appreciated.
Stu
(552 Views)
