VeriStand
Veristand Swapping XNET Database
I want to update the NI-XNET CAN database in my Veristand project for a more recent version. However, it does not appear that there is any way to do this in-place. There are two options I can see, but neither work for me. I can delete the DB and add a new one. However, this will delete the CAN channels and periodic sending that I have set up for this. I then would need to go and manually re-add these. Or, I can replace the file. However, the file has the version in the name, and as the project is using the file/alias Veristand will not allow editing it.
Is there a way to change the XNET database in-place, without destroying other parts of the project?
(576 Views)
Replace the file, then in the System Explorer select Refresh Databases. Alternatively, select Launch XNET Database Editor to edit your file there.
https://tmesystems.net/
(569 Views)
