VeriStand
Bulk Removing Channels in Veristand System Channel View
I have Veristand project, and I am tidying up the system channel mapping. I have removed a large number of CAN signal channels that were not being used from the system definition, however they do not get removed from the system definition mapping page. Instead, within my XNET CAN block every single channel I have removed is labelled as broken. When this happens, Veristand crawls to a stop and is barely responsive. Is there a way to bulk-remove channels from the channel mapping page? The only way I can see is to do it one-by-one. But given that there are 100+ signals and Veristand becomes extremely slow, it takes 1+ second just to right click on a broken channel to remove it so it would take a very long time to remove them all.
(1,648 Views)
Accepted by topic author Slippers
If you are using the Mapping Diagram, you can remove the broken items with a single click.
If you are using the System Mapping from the System Explorer, you can export the mappings to a txt file and modify it using Notepad++.
https://tmesystems.net/
(1,633 Views)
Nice one, thank you
(1,616 Views)
