SignalExpress
Simultaneous digital and analog acquisition (cDAQ-9174)
Hi all,
I have two flow meters in series and I have to acquire flow rate data from each, simultaneously.
--FLOW METER 1: hall-effect flowmeter (see attachment). Its output are DC square waves (digital output) whose frequency is proportional to flow rate.
In order to acquire from this meter, I have a NI-9411 card.
In SignalExpress I did: Acquire Signal >> DAQmx Acquire >> Counter Input >> Frequency
--FLOW METER2: electromagnetic flowmeter (TOSHIBA, see attachment) model GF630/LF620, whose output is an analog signal, whose voltage is proportional to flow rate.
In order to acquire from this meter, I have a NI-9203 card.
In SignalExpress I did: Acquire Signal >> DAQmx Acquire >> Analog Input >> Voltage
Both the cards are in a NI cDAQ-9174 chassis.
My question is: Is it possbile to acquire signals simultaneously from flowmeter1 and flowmeter2 and than download data in .txt?
Every suggestion would be more than appreciated.
Thank you in advance.
Best wishes
Agostino Ghetti
(3,711 Views)
Hi Agostino,
you can synchronize the two acquisitions.
For the first flowmeter you need a buffered counter input with the same sample rate of the AI acquisition (that will be AI sample clock).
Refer to the following guide for the synchronizations metodology: https://www.ni.com/en/support/documentation/supplemental/21/signal-based-synchronization-of-analog-i...
(3,685 Views)
