How do you do a complete system backup of a sbrio system
I want to be able to backup a complete system (sbrio) and a windows PC.  We use Acronis Echo workstation to undertake the backup of the PC, but If I understand correctly this will not run on the RT system.
Does NI have a tool to allow a snapshot of a system (sbrio) to be backed up, and then deployed to an identical sbrio to allow 100% compatability between these 2 units.
I believe we have seen this in the past, could anyone help me with this.
A.
(3,492 Views)
Accepted by jspinozzi
This and this may help.
(3,478 Views)
Another option is the RT Application Deployment utility, which is built on top of the RT System Replication tools in LabVIEW 2009. These VIs started shipping as part of the product in 2009.
https://www.ni.com/en/support/downloads/software-products/download.replication-and-deployment-utilit...
The released version of the RT Application Deployment utility won't detect sbRIO targets, but a very slight change in one of the subVIs will enable sbRIO targets as well. So if you are using LV 2009 then this is another option and I can help you make that change. I will include it in the next release of this utility.
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
(3,470 Views)
