realtime application deployment error
I have a Real Time FP 2200 which I have developed an application for it runs fine from the development environment and the application seems to build fine, however when I set this application to run at startup it starts the deployment process which fails everytime when deploying on a XDNodeRunTimeDep.lvlib. Can anyone help here?
(3,275 Views)
Hi rocke72,
I have a couple basic questions regarding your issue. What operating system are you using? What version of LabVIEW (Real-Time) are you using? What sorts of things does your application do? What software do you have installed on the cFP-2220?
Thank you for choosing National Instruments.
Aaron Pena
http://www.ni.com/support
(3,260 Views)
