how to automatic detection of 3 or 4 wire rtd type
hi all,
I am doing a project with NI 9217 device  and try to measure temperature with RTD senser,
as I read at NI website this module can be automatic detect 3 or 4 wire RTD type ( read this link: https://www.ni.com/en-us/shop/model/ni-9217.html
but i do not know how to config and program to do this function
anyone can help me to make it clealy
Thanks you very much!
(3,810 Views)
As you said... It is automatic so just hook up your RTD according to the diagram in the manual.  If it is 4 wire then the current is supplied via EX+, if it is 3 wire then RTD+ is used.
The only setup option that I am aware of is the sample rate of the module which can be set to 200ms or 2 ms.  200ms will give you much better filtering against 50/60 hz noise.
(3,799 Views)
If you look on page 8 of the manual (https://www.ni.com/docs/en-US/bundle/374187f/resource/374187f.pdf) there is a description of what is meant by autodetect.
Chris Bakker
SET Americas
CEO
(3,791 Views)
I have  understood and solved the problem.
thanks you very much!
(3,752 Views)
