RTI DDS Toolkit for LabVIEW Support
NI System Configuration IPAddr Property Fouls up RTI DDS Writers
I am using LV2018 on a RT Linux Target and have found that opening a NI System Configuration Session and obtaining the IPAddr property will hose up the ability to open a RTI DDS writer.  If I remove the IPAddr property everything works fine.  Any Ideas what could cause this to happen?
(6,456 Views)
Actually it turns out that the IPAddr property is fine, it is the string itself that seems to be incompatible with the write cluster I am using.  For some reason any strings like 192.168.1.249 that begin with a numeric do not work.
(6,441 Views)
Accepted by viScience
When you create a writer with a string containing a numeric value, it uses that value as the maximum length of the string. Perhaps that is related to what you are seeing?
(6,431 Views)
Thanks!  That was really driving me crazy as I was unintentionally wiring a numeric string constant into my complexType when I created the Writer.
Starting to really like the RTI DDS toolkit.  It is a totally underappreciated tool gifted to us by NI.
(6,419 Views)
Hi,viScience!Can you send me a copy of the Linux version of LabVIEW 2018?Recently, I wanted to use LabVIEW in Linux system, but I couldn't find a suitable version of labview.I hope I can get your help! Thank you!My E-mail:yison_lee@163.com.Thanks again!
(6,195 Views)
