PXI
PXIe4472
We have here several PXIe4472 modules and we were planning to use them for a test. We also have some iepe accelerometers. Going through the specifications of the module I've realised there's a high pass filter with a cutoff frequency of 3.4Hz when AC coupling is enabled. This is a huge problem for us since the first interesting phenomenon we want to capture is likely to happen below that. My question is then, can I enable DC coupling (to get rid of that filter) and still feed the IEPE accelerometers (typically they need a constant 4mA current)? I don't have all the equipment now with me and I cannot test it myself.
Thanks!
(3,180 Views)
You could use the DAQmxChannel property node to set the coupling.
Sorry, I misunderstood the question.
Maybe this link might help clarify your question regarding using IEPE excitation together with DC coupling.
BR
(3,169 Views)
Thanks for your response. I'm afraid my question is more at a hardware level, when I DC couple a particular channel within a PXIe4472 can I still connect a IEPE Accelerometer or will I have to find an external current source because the module is not suplying it anymore (for DC Couple enabled). Not sure if I explain myself.
(3,163 Views)
Oh, the link was very useful, thanks indeed.
(3,161 Views)
