NI TestStand
Where can I specify the directory for the .xml log
I am a new user of TS.
As the .xml log generated at the directory of the .seq file, I want to specify another folder for the .xml log, where can I config it ?
(1,302 Views)
Configure>>ResultProcessing...
Then click on the button with the hammer and wrench on the line for the XML report.
On the Report File Pathname tab of the Report Options dialog you should be able to change where the reports are being generated.  Click the help button on that dialog to see what the different fields mean.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(1,258 Views)
