NI TestStand
Installation Order
I'm a systems administrator setting up computers for an RF training environment and I have a question related to the installation order, if necessary.  I've read about installing LabView older programs first, then  drivers, etc.
Below are the following items I was tasked with installing.  Based on what I have to install, is there any set order to the items? NOTE:  This is for an air-gapped system (intranet only).
Thank you.
I have the following to install-
NI-488.2 (v.19.5)
NI-VISA (v.19.5)
NI CompactRIO (v.20.5)
NI R Series Multifuntion RIO 20.0
NI DAQmx (v.20.1)
NI Industrial Commmunications for EtherCAT (v.20.0)
(1,027 Views)
Accepted by WillK68
There is no order you can install them one by one
CLA
(1,013 Views)
That is very untrue.  There is a strict order if you want all your hardware to work correctly and development software to recognize which drivers to install.  Your comment is irresponsible.  I will comment back later with the specific order.  I do this about every two years and have to teach myself the hard way again and again.
(50 Views)
Apparently, the development software is already installed, because it is not on the list.
(22 Views)
