09-30-2024 10:27 AM
I'm a systems administrator setting up computers for an RF training environment and I have a question related to the installation order, if necessary. I've read about installing LabView older programs first, then drivers, etc.
Below are the following items I was tasked with installing. Based on what I have to install, is there any set order to the items? NOTE: This is for an air-gapped system (intranet only).
Thank you.
I have the following to install-
NI-488.2 (v.19.5)
NI-VISA (v.19.5)
NI CompactRIO (v.20.5)
NI R Series Multifuntion RIO 20.0
NI DAQmx (v.20.1)
NI Industrial Commmunications for EtherCAT (v.20.0)
Solved! Go to Solution.
09-30-2024 11:28 AM
There is no order you can install them one by one
05-01-2026 01:45 PM
That is very untrue. There is a strict order if you want all your hardware to work correctly and development software to recognize which drivers to install. Your comment is irresponsible. I will comment back later with the specific order. I do this about every two years and have to teach myself the hard way again and again.
05-02-2026 04:35 PM
Apparently, the development software is already installed, because it is not on the list.
