NI TestStand
How to use the DisplayEditNumericFormatDialog method of Teststand API
I have to build a coustom report generator plugin for Teststand by using c#. In the Teststand API there is a method integrated called "DisplayEditNumericFormatDialog"
http://zone.ni.com/reference/en-XX/help/370052M-01/tsapiref/reftopics/propertyobject_displayeditnume...
Is there a way to set the sample value of the window that will appear if the method is called?
Window
I do the following things:
 private void button1_Click(object sender, EventArgs e)
            mChanged = true;
            bool tempbool;
            PropertyObject tempobject = mEngine.NewPropertyObject(PropertyValueTypes.PropValType_Number, false, "", 0); //creates a temporary PropertyOgject to show the EditNumericFormatWindow
            tempobject.NumericFormat = mConfig.GetValString(P_PluginSpecific_Options_NumericFormat, 0); //read the numeric format of the plugin options
            tempobject.DisplayEditNumericFormatDialog("Numeric Format", out(tempbool), 1); //Show the EditNimericFormatWindow
            if (tempobject.NumericFormat == "") mConfig.SetValString(P_PluginSpecific_Options_NumericFormat, 0, "%$.13g");
            else mConfig.SetValString(P_PluginSpecific_Options_NumericFormat, 0, tempobject.NumericFormat);
            MessageBox.Show(tempobject.NumericFormat.ToString());
thanks in advance
(4,240 Views)
Hwllo f4bo
in TS i used an expression with this syntax
RunState.Engine.DisplayEditNumericFormatDialog("","%2.2d",0,20)
the last value set the sample value
Hope it helps
best regards
Alexander
(4,211 Views)
Accepted by f4b0
Hello f4bo,
attached a sequence which show how this can be done.
Locals.Local = RunState.Engine.NewPropertyObject(PropValType_Number, False, "",0x1),
Locals.Local.AsPropertyObject.NumericFormat = "%b",
Locals.Local.AsPropertyObject.SetValNumber("", 0, 20),
Locals.Local.AsPropertyObject.DisplayEditNumericFormatDialog("Fake title", False, 0)
best regards
Alexander
(4,183 Views)
Hello Duffy2007
this solution does work!
thanks for your quick support!
(4,173 Views)
