NI TestStand
Pass Fail test MemberType
If I modify programmatically a pass fail test, I used Step.AsPropertyObject.SetValNumber(“TS.SData.Call.MemberType”, 0, -1), the step is modified with a number: (2147483647),  expected value :  “Do Not Call”
If I try with other argument: 1 (Call Method), 2 (Get Property), 3 (Set Property) it’s works well.
Someone have a solution to my problem?
I used TestStand 4.0
By advance thank you for your help
Romuald.
(4,484 Views)
I don't know exactly what you are expecting to do programmatically, but you should use the ActiveXModule class. Try somthing like this :
Step.AsPropertyObject.AsStep.Module.AsActiveXModule.MemberType = 1   // or an other valid value
(4,462 Views)
First, thank you for your answer.
I add programmatically in a new sequence, a passfail test step, and I change programmatically the step’s properties
NewStep.AsPropertyObject.SetValNumber(“TS.Data.call.ObjectVariable”, 0, “RunState.Engine”)
NewStep.AsPropertyObject.SetValNumber(“TS.SData.Call.InterfaceName”, 0, “Step”)
NewStep.AsPropertyObject.SetValNumber(“DataSource”, 0, “My true/false test”)
The step in the new sequence is well modify, but with the following one, it doesn’t work:
NewStep.AsPropertyObject.SetValNumber(“TS.SData.Call.MemberType”, 0, -1)
I want to configure the new step with “Do not call”, this step works well if I used argument 1 (Call Method), 2 (Get Property), 3 (Set Property), but don’t want to get or set a property, I just want to run the step and have a pass fail test in the new sequence.
I hope my explanations are clear.
Best regards
Romuald
(4,458 Views)
Accepted by topic author Romuald123
Okay, this could be a solution (tested with TestStand 4.2.1) :
NewStep.AsPropertyObject.SetValBoolean("TS.SData.Call.MakeCall", False, 0x0)
Let me know if it's ok for you...
(4,449 Views)
It's ok for me thank you very much, very helpful 🙂
 Best regards
Romuald
(4,446 Views)
