NI TestStand
TestStand Deployment Utility Error -19049
I'm running into an error when trying to create a deployment of TestStand (process model, UI, etc).  Specifically, I want to install the UI and process model into an absolute path, and that's where I'm running into the issue.  When I install to program files, the deployment works without a problem, however, I run into issues when trying to find files in things like Property Loader and the like.
To duplicate the problem:
In the Installer Options tab, "Default Installation Base Directory:" is set to Absolute Path.  And the Default Installation Directory is basically set to anything (I've tried my desired directory, just C:\, and everything in between, but doesn't seem to make a difference)
When building, the Build Status tab shows the error number -19049 with message "Destination not supported under the current bitness" and the message "Default Installation Base Directory: using the following destination System WOW64 Directory"
I'm using TestStand 2014 32-bit with Labview 2015 32-bit on a Windows 7 64-bit OS.  I can't change the bitness of TS or LV because of DLLs I'm referencing that can't be changed.
Can anyone help?
(4,727 Views)
In your deployement, what is the installation base  directory you set ? (Installer tab)
It might point on your 'program files' or other system folder specific to 64-bits OS. If so, you should consider forcing the installer to base directory to point on a specific 32-bit folder (Program Files (x86)' for example...
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
(4,719 Views)
The problem arises when I set the installation base directory to absolute.  I've tried pointing that location to the root C directory, an arbitrary folder created with all permissions, and so on.  None of those options work.
I don't have a problem if I use the Program Files directory, as the Deployment Utility picks the right Program Files folder.
(4,707 Views)
Accepted by topic author Seth_K
Hi Seth_K,
This is a known bug which has been fixed in TestStand 2014 SP1; see issue ID 529404 in the 2014 SP1 Bug Fix List:
https://www.ni.com/en/support/documentation/bugs/15/teststand-2014-sp1-bug-fixes.html
The only known workaround besides upgrading to TestStand 2014 SP1 is to use a relative destination instead of absolute. If upgrading to TestStand 2014 SP1 is not an option, let me know and we can look into other options.
Al B.
Staff Software Engineer - TestStand
CTA/CLD
(4,702 Views)
Hi Al,
Thanks for the heads up.  I updated and it resolved the issue.
-Seth
(4,682 Views)
