08-07-2012 03:41 PM
I am using CSV file generated by TestStand 4.5 import/export function that has one of the string variable with comma in it ("This is comma, Test."). But the property loader can't load this file and errors out. Is there a way to solve this problem? I do not want to use the tab txt file as csv is more readable.
Thank you,
Hiren
08-08-2012 09:58 PM
Hey Hiren,
Thanks for posting! When you say the property loader errors out, do you see an error window or associated error code? If so, could you provide a screenshot?
08-10-2012 11:41 AM
Hi Courtney,
Thanks for the reply. The error screen shot.
The CSV file looks like:
START
<Step Name>
<Locals>,Variable Value
<FileGlobals>,Variable Value
testString,"This is comma(,) test."
<StationGlobals>,Variable Value
END
Hiren
08-10-2012 11:53 AM
Sorry, but there's no way to discrimate a comma being a delimiter and a comma as part of a value. I think in this instance, you are going to have to go to the tab delimiter.
