CSV with comma in string
I am using CSV file generated by TestStand 4.5 import/export function that has one of the string variable with comma in it ("This is comma, Test."). But the property loader can't load this file and errors out. Is there a way to solve this problem? I do not want to use the tab txt file as csv is more readable.
Thank you,
Hiren
Hiren Patel
(3,921 Views)
Hey Hiren,
Thanks for posting! When you say the property loader errors out, do you see an error window or associated error code? If so, could you provide a screenshot?
(3,902 Views)
Hi Courtney,
Thanks for the reply. The error screen shot.
The CSV file looks like:
START
<Step Name>
<Locals>,Variable Value
<FileGlobals>,Variable Value
testString,"This is comma(,) test."
<StationGlobals>,Variable Value
END
Hiren
Hiren Patel
(3,885 Views)
Sorry, but there's no way to discrimate a comma being a delimiter and a comma as part of a value.  I think in this instance, you are going to have to go to the tab delimiter.
(3,882 Views)
