I have a solution with one underscore character in its file name. It is properly displayed in the window title bar, but undescore is missing in most recently used files, under File menu.
I made some complementary tests, with dummy solution files named Undescore_One.pbs, Undescore_One_Two.pbs and Undescore_One_Two_Three.pbs. Only the first underscore in the file name is missing in menu display:
I bet is due to an old Windows menu standard that is no longer used. The underscore was used to denote the underlined letter for the keyboard shortcut to select the item in a menu. A reason I like spaces 😁
__________________________________ Bill Eisenhower Certified LabVIEW & TestStand Developer
