NI Linux Real-Time Discussions
Mounting a folder
HI there,
did ever anyone encounter issues when connecting to a share that has a DFS Filesystem? Just looking where I can find keyutils that I can install
Message 31 of 32
(1,026 Views)
Hi there, philipp.n,
I hadn't had a chace to look into it further until now, but I've had difficulty tracking down a pre-built package for this that would work with our targets. I would recommend building the source on your target once the appropriate tools are installed and available.
I don't have a DFS network configuration to try this out on, but I was able to build and install the keyutils package as follows:
From your target:
// Update the on-target feed view
opkg update
// Install packages needed to get and build the component
// packagegroup-core-buildessential - covers most of the build tools
// coreutils - provides the "install" program
// findutils - replaces the busybox "find" which does not provide functionality needed by the source
// ldd - used by the source build process
// file - needed by the source build process
// git - source control system that is used to control keyutils
// sed - replaces the busybox "sed" which does not provide functionality needed by the source
opkg install packagegroup-core-buildessential coreutils findutils ldd file git sed
// Clone down (download) the source from upstream
git clone git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/keyutils.git
cd keyutils
// Set up some variables needed by the source build
export LIBDIR=/lib
export USRLIBDIR=/usr/lib
// Build and install
make
make install
Message 32 of 32
(1,026 Views)
