NI Linux Real-Time Discussions
Cursor Reference Invalid for cRIO 9030
I found this potential bug with the event structure in a cRIO 9030. If you look at the picture below I get the position from a cursor two different ways. The first is through the event structure's Cursor Reference output, and the second is using the XY Graph'sProperty Node to get the Cursor Reference. Using the event structure I get an error 1055 saying the reference is invalid. It works fine using the XYGRaph's Property Node.
I know Cursor VIs are not supported on the Linux.
What worries me, and I show this in the picture of the probe below, is that the references I get back are different. So this may be a bug of a larger problem of event structures returning incorrect references.
(3,612 Views)
Hi LJHerskowitz!
I recommend contacting your local support team with this issue. This issue is in the realm of support and also something we will want to further investigate and document.
If you have any questions on who to contact then please feel free to message me and I can help you get started.
(3,296 Views)
