NI Linux Real-Time Discussions
Building & installing a package - Libusb
In a recent previous post I asked about using the d2xx ftdi drivers. I'm now at the stage of trying to install libusb (a dependent package) on my system.
I've installed the build tools:
     opkg gcc gcc-symlinks
And I've downloaded the source from http://www.libusb.org/wiki/libusb-1.0 and put it on the target. Following the instructions in 'install' file I've then tried calling './configure' but get told 'permission denied'. I then tried running 'make install' but get told 'No rule to make target 'install'. Stop'.
I'm now stuck. Can anyone help me understand how to build & install the package please, I've not done it before.
Martin
(5,647 Views)
Accepted by topic author MartinMcD
If you are using the 2014 or 2015 software release on your target then I believe libusb is available in the feeds provided by NI and no compilation should be needed.
Try running:
opkg update
opkg install libusb-1.0-0
And if you want the development bits:
opkg install libusb-1.0-dev
(4,943 Views)
I ran 'chmod a+x -R ./configure' which meant ./configure would then run although it reported an error.
(4,943 Views)
Ahh great, thank you. I'd tried opkg install libusb but now libusb-1.1-0. That's installed now, great.
(4,943 Views)
Sorry I didn't make that clearer in your previous post, MartinMcD. Thanks gratian.crisan
(4,943 Views)
