NI Linux Real-Time Discussions
Silex SX-SDCAN2 Bluetooth Support with SOM
Greetings,
I'm developing a SOM carrier board and need both Wifi and Bluetooth. There is some great information in this forum about how to get the Wifi working but I have not seen anything relative to the Bluetooth portion of the Silex SX-SDCAN2 module. Is it possible to use the Bluetooth portion of this module with the NI Real-Time Kernel? The only profile I need is SPP. Any thoughts or ideas would be appreciated.
Thanks.
-Brent
(3,828 Views)
The in-kernel BT protocol handling is not enabled in the shipping NI Linux RT kernels as there's been little interest. Of course, I may be a little biased, but building and booting a new kernel  is relatively easy, following the instructions on the github page (adjust if you're not using the 15.0 software stack)
(3,314 Views)
Hmm, I just checked NI's 2015 feeds and, sadly, they don't have the userspace side of the equation (bluez-utils). This means that you'd need to rebuild the kernel as well as build the packages for the userspace side (detailed here). If there's sufficient interest in such features, that's certainly a possibility but the demand needs to be there prior to justify the investment.
(3,314 Views)
