Multisim and Ultiboard
help with multisim 12
Hi
I´m new to multisim, and this is my first circuit, I´m making a 3-5 watts Class A, audio amplifier and I need to find a 2 pin terminal blocks for the input and output to be used to laying out a wiring diagram, I´m using multisim 12 ... and I can´t find it... thanks for the help.
Newbie
(2,294 Views)
Hi Javirama,
You can check this forum:
https://forums.ni.com/t5/Multisim-and-Ultiboard/Create-screw-terminal-block-in-Multisim/td-p/2637917...
Or you can create your own Custom Component in NI Multisim:
http://www.ni.com/tutorial/3173/en/
I hope this works for you
(2,261 Views)
