Multifunction DAQ
reduce timing for 8x8 matrix display
Hi all,
i am working on a 8x8 led matrix display. i'm using scanning method and thus requires alot of stacked sequence loops.
when trying to make different patterns, i am still unable to overcome the flickering no matter how well i simplify the program.
 i realise that this is due to the default time delay of a stacked sequence.
may i know how to eliminate or reduce this time delay to get a firm pattern?
Pls help me solve this problem.
Vivek
Message 1 of 8
(3,601 Views)
Did you post this a few weeks ago?  It seems like I remember someone posting about an 8x8 matrix.  It inspired me to see if I could create a moving message board, which I did.  Send me the code (if possible) and I'll take a look.  I don't know that I can judge enough from your description to know what to do to solve the problem.
Message 2 of 8
(3,589 Views)
hi,
thanks for the reply. I'll attach the file. But my 8x8 led matrix is a seperate hardware. I am using voltage and transistor fieldpoint modules to control the hardware. The file attached is a program for a definite pattern '9'.
The problem with the program now is that the pattern flickers alot. I am working to get a firm pattern without flickering. I doubt my program is too slow.
Pls try to help.
vivek.
Message 3 of 8
(3,567 Views)
Sorry, I thought you were using LabVIEW front panel LED's.  I'll gladly look at your code, but I don't know anything about using FieldPoint or real LEDs, so I may not be of much help.  I am sure others would be able to help, though.
Message 4 of 8
(3,560 Views)
ok sure. thanks anw. Smiley Happy
Message 5 of 8
(3,545 Views)
Hi Vivek,
What hardware are you using to drive your LED matrix?  It sounds like the flicker might not be due to your VI.  If you post your code I'll take a look at it to see if it might be responsible.
Eric A.
Distributed I/O Product Support Engineer
Message 6 of 8
(3,526 Views)
hi,
yup i believe its my software which is causing the flickering problem and i would appreciate if u could help on modifying my software.
i am using Voltage module (cFP-DO-410) and transistor module (cFP-DO-403). and the LED matrix is a pcb board with 64 LEDS in a 8x8 arrangement.
the selection of channels to light up is in the properties of the fieldpoint in the blockdiagram. and i believe u need the modules inorder to check how the property setting actually looks like.
Message Edited by vivek88 on 10-09-2007 09:10 AM
Message 7 of 8
(3,519 Views)
Hi
I think you might try introducing a wait into your loop. I know my suggestion sounds odd since you are seeing flicker but this way you know when your processor is taking a break to perform other tasks. I think it would be pretty hard to replicate the issue without your hardware. Let me know what effect, if any, that has on your application.
Eric A.
Message 8 of 8
(3,497 Views)
