10-09-2007 09:44 PM
10-11-2007
03:50 AM
- last edited on
04-20-2026
04:56 PM
by
Content Cleaner
Hi caveman07,
The AI Hardware config.vi sounds like a traditional NI-DAQ VI. Traditional DAQ is the predecessor for DAQmx and DAQmx Base. It is programmed differently and you will need to transition your Traditional NI-DAQ VI's to DAQmx Base VI's if that is the case. MAC OS 9 and previous used Traditional NI-DAQ and MAC OS X uses DAQmx Base. Check out this Developer Zone for help on transitioning from one driver to the next.
I hope this helps!
