10-02-2007 01:56 AM
10-02-2007 06:38 AM
10-05-2007 01:09 AM
hi,
thanks for the reply. I'll attach the file. But my 8x8 led matrix is a seperate hardware. I am using voltage and transistor fieldpoint modules to control the hardware. The file attached is a program for a definite pattern '9'.
The problem with the program now is that the pattern flickers alot. I am working to get a firm pattern without flickering. I doubt my program is too slow.
Pls try to help.
vivek.
10-05-2007 07:24 AM
10-06-2007 05:19 AM
10-08-2007 08:10 PM
10-09-2007 09:06 AM - edited 10-09-2007 09:06 AM
hi,
yup i believe its my software which is causing the flickering problem and i would appreciate if u could help on modifying my software.
i am using Voltage module (cFP-DO-410) and transistor module (cFP-DO-403). and the LED matrix is a pcb board with 64 LEDS in a 8x8 arrangement.
the selection of channels to light up is in the properties of the fieldpoint in the blockdiagram. and i believe u need the modules inorder to check how the property setting actually looks like.
Message Edited by vivek88 on 10-09-2007 09:10 AM
10-10-2007 11:11 PM
