Multifunction DAQ
myDAQ analogue voltage measurement incorrect
I am trying to read an analog signal from a sensor using the myDAQ. I could only manage to pick up a very faint signal. I then plug it to a signal generator, the 5V signal only reads as 88mV on the myDAQ. Has the DAQ gone bad? Thanks for any help.
(2,070 Views)
Accepted by topic author samAAF
As a test could you please connect the AI terminal to the +5V terminal and see the result (and nothing elce)?
Otherwise, I recommend you open an RMA request.
__________________________________________
The best way to thank, is to give KUDOS
(2,036 Views)
It was the poor soldering to the BNC connector
(1,965 Views)
