Multifunction DAQ
Unable to load MIFSystemUtility DLL
To solve this error, you must manually delete the MIFSystemUtility registry key.
  1. Open the Registry Editor. (In Windows 10, type regedit into the search bar and press Enter).
  2. Navigate to the following registry key: Computer\HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\National Instruments\Common\Installer\MIF\MIFSystemUtility
  3. Right click the key MIFSystemUtility key in the file tree and click Delete.
After deleting the registry key, you should be able to install the software without error.
Message 11 of 19
(4,315 Views)
I did this, and it still doesn't work. Any other suggestion?
Message 12 of 19
(4,080 Views)
The link is not working...
Message 13 of 19
(3,811 Views)
Working, thank you very much
Message 14 of 19
(3,692 Views)
I dont know if you already found a solution and fixed your problem but I fixed mine when I encountered the same problem by going to the package installer, select the items there, and then click the repair button.
Message 15 of 19
(3,229 Views)
Deleting the registry key worked for me.
Message 16 of 19
(3,170 Views)
I have the same problem, but the solution u gave doesn't work for me. Any other ideas?
'An unknown error occurred.
Additional error information:
Unable to load MIFSystemUtility DLL.'
Message 17 of 19
(1,806 Views)
Hi All,
Installing NI488.2 online or offline will solve the MIFSystemUtility.dll.
Enjoy programming
Message 18 of 19
(1,747 Views)
I've encountered the same error today. Unfortunately, deleting the registry keys didn't help. BBut these steps worked for me:
1. Remove NI Software via NI-Packetmanager
2. Remove NI-Packetmanager
3. Delete National Instruments folder from C:\Program Files\, Program Files (X86), and C:\user\xxx\local\
4. Remove National Instruments folder (key) in registry: Local-Machine->Software->National Instruments and in Wow64Note
5. Reboot
Then I was able to install the Packetmanager and CVI Software without any error!!
Message 19 of 19
(802 Views)
