07-09-2020 01:38 AM
To solve this error, you must manually delete the MIFSystemUtility registry key.
After deleting the registry key, you should be able to install the software without error.
11-16-2021 09:59 AM
I did this, and it still doesn't work. Any other suggestion?
03-23-2022 12:12 AM
The link is not working...
04-11-2022 02:59 AM
Working, thank you very much
08-28-2022 09:07 AM
I dont know if you already found a solution and fixed your problem but I fixed mine when I encountered the same problem by going to the package installer, select the items there, and then click the repair button.
09-21-2022 02:10 PM
Deleting the registry key worked for me.
