‎07-09-2020 01:38 AM
To solve this error, you must manually delete the MIFSystemUtility registry key.
After deleting the registry key, you should be able to install the software without error.
‎11-16-2021 09:59 AM
I did this, and it still doesn't work. Any other suggestion?
‎03-23-2022 12:12 AM
The link is not working...
‎04-11-2022 02:59 AM
Working, thank you very much
‎08-28-2022 09:07 AM
I dont know if you already found a solution and fixed your problem but I fixed mine when I encountered the same problem by going to the package installer, select the items there, and then click the repair button.
‎09-21-2022 02:10 PM
Deleting the registry key worked for me.
‎03-22-2024 12:29 PM
I have the same problem, but the solution u gave doesn't work for me. Any other ideas?
'An unknown error occurred.
Additional error information:
Unable to load MIFSystemUtility DLL.'
‎03-28-2024 12:29 PM
Hi All,
Installing NI488.2 online or offline will solve the MIFSystemUtility.dll.
Enjoy programming
‎04-01-2025 02:51 AM
I've encountered the same error today. Unfortunately, deleting the registry keys didn't help. BBut these steps worked for me:
1. Remove NI Software via NI-Packetmanager
2. Remove NI-Packetmanager
3. Delete National Instruments folder from C:\Program Files\, Program Files (X86), and C:\user\xxx\local\
4. Remove National Instruments folder (key) in registry: Local-Machine->Software->National Instruments and in Wow64Note
5. Reboot
Then I was able to install the Packetmanager and CVI Software without any error!!
