Multifunction DAQ
取消
顯示結果
搜尋替代
您的意思是:
USB 6212 LED not lighting up
My USB-6212 DAQ system isn't working properly. When I plug in the usb to the laptop and check MAX to see if it is connected, it says it isn't but the DAQ system is discoverable. Also, the LED light is not turning on either. Anyone know how to resolve this issue?\
Thank you
0 積分
1 條訊息(共 8 條)
5,872 檢視
Hi riasadik,
Does the device show up in the Windows Device Manager (assuming you are using Windows) when you plug it in?
0 積分
2 條訊息(共 8 條)
5,850 檢視
Hi
Thank you for the response.  Yes, the device shows up as "Unknown Device". I used a different computer to see if that was the issue, and it still isn't lighting up.
0 積分
3 條訊息(共 8 條)
5,836 檢視
Also, Windows notifies me that the device requires troubleshooting.
0 積分
4 條訊息(共 8 條)
5,835 檢視
What version of DAQmx did you install?
0 積分
5 條訊息(共 8 條)
5,831 檢視
Okay so I installed the newer version of DAQ. It is finally lighting up (unlike before), but now it is blinking. I am not getting a solid LED light. Why is this happening and how can I fix it?
0 積分
6 條訊息(共 8 條)
5,779 檢視
0 積分
7 條訊息(共 8 條)
5,778 檢視
Take a look at the manual for the USB 6212 http://www.ni.com/pdf/manuals/371931f.pdf
Section 3-6 gives info regarding the PWR/ACT LED Indicator. It looks like a single-blink means the device is operating normally (connected to USB Hi-Speed port) and a double-blink means its operating normally (connected to USB Full Speed port. It appears the blinking is a good thing!
0 積分
8 條訊息(共 8 條)
5,765 檢視
