If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
05-26-2005 03:28 AM
05-27-2005 11:49 AM - last edited on 01-25-2012 03:43 PM by JordanG
03-31-2009 08:09 PM
I went to add/remove, clicked on the NI option, and selected everything, and all that was there got removed, and i restarted my computer (XP).
I went to my program files, and the NI directory along will many folders are still there (36M total). I tried to run MSI blast, but no NI are listed, so I cannot run anything. I tried to manually delete the folders, and I got an error saying I cannot delete (....dll)
Any solutions? I basically just want to fully remove NI from my computer so that I can install labview 8.6 only.
04-02-2009 04:43 AM
I am having the same problems. I found this .pdf however, that can give some clues to some more action needed, among other things the deletion of values from the registry. See the following link for the accompanying MSIBlast pdf. http://forums.ni.com/ni/attachments/ni/250/34391/2/MSI%20Blast.pdf
01-23-2012 05:42 PM
Disclaimer:
Using the MSI Blast tool is not encouraged as it can not only uninstall all NI products, but may also result in lost data. Please speak with an NI engineer before running the MSI Blast executable.
05-21-2012 03:38 PM
Here's an updated related post using the NI-shipped NIUninstaller.
12-04-2012 03:07 AM
Hi all ;
Also I need MSIBLAST.exe could you send it to me ?
12-04-2013 09:27 AM
Can I have a copy of msiblast? I need one as well
02-10-2014 02:08 PM
Hi all,
This thread has come back to life a few times. To clarify, MSI Blast is an unofficial tool that can be used to uninstall NI Software. The vast majority of uninstallations are successful using the recommended process for uninstalling National Instruments software. MSI Blast is very rarely used as a troubleshooting step in cases where software fails to uninstall, and we encourage you to contact NI Support if you are experiencing difficulty with the uninstallation process.
Jeff Peacock
Product Support Engineer | LabVIEW R&D | National Instruments
