Multifunction DAQ
Can data be read into LabView from a GPS through the USB?
I have a DeLorme Earthmate GPS receiver. It connects to my computer via a USB port. I'd like to use LabView to record latitude, longitude, and altitude from it. Can this be done?
Message 1 of 10
(5,287 Views)
Hello JSlane,
There is a tutorial on National Instruments website for communicating with a USB device in LabVIEW using VISA. In order to use this method, however, you will need to know what commands need to be sent to your GPS receiver.
One other option is making calls from LabVIEW to a .dll file used by your device. There is also a tutorial for doing this.
If none of these suggestions help, or if I�m not correctly understanding your issue, please post the software and versions you are using, the applicable portions of your code, and any other
information that may help, and I�ll be happy to look further into it.
Have a nice day and good luck!
Robert M
Robert Mortensen
Software Engineer
Message 2 of 10
(5,287 Views)
Robert,
I am using a Garmin GPSMap 60c set to a NMEA output format, 4800 baud. I viewed the tutorial on communicating with a USB device using NI-VISA. However, when I connect the Garmin to my laptop, the device does not show up in NI MAX Devices and Interfaces.
I have Labview 2013 operating on a Windows 7 OS.
Jean
Message 3 of 10
(4,553 Views)
How does the device appear in Windows device manager? You say it is set for 4800 baud and that implies it is a virtual com port and would appear in MAX as such. Don't bother with the VISA Wizard unless you have the very low level protocol from the vendor.
Message 4 of 10
(4,545 Views)
It doesn't appear at all.
Message 5 of 10
(4,536 Views)
If it doesn't appear in Windows device manager, then the driver from the vendor is not installed.
Message 6 of 10
(4,534 Views)
It does appear in the Windows device manager at this location: Port_#0003.Hub_#0004
It does not appear as a USB device in MAX.
Message 7 of 10
(4,527 Views)
Your answers are confusing. How does it appear in device manager? What driver is it using?
Unless it's a serial port emulator, USBTMC, or you use the wizard, it's not supposed to appear in MAX.
Message 8 of 10
(4,524 Views)
Sorry, I misunderstood a previous questons. My Garmin GPSMax 60c does appear in the Windows Device Manager. See attachment.
I would like to be able to read data from the GPS into a Labview VI and am trying to figure out how to communicate with it.
Message 9 of 10
(4,518 Views)
I still don't know anything about the Windows driver you are using.
In any case, if it's not emulating a serial port, your comment about baud rate does not make any sense. You can attempt to get the very low level protocol spec from garmin and use the wizard or get the specs on the existing driver and call that with the Call Library Function Node.
Message 10 of 10
(4,515 Views)
