Multifunction DAQ
PCI 6221 counter clock source
I am using PCI 6221 counter set as Linear encoder with external clock type setting.  I did try with Ctr1InternalOuput which shows in the 6221 manual but the VI it returns an error stating
Possible reason(s):
Specified route cannot be satisfied, because the hardware does not support it.
Property: SampClk.Src
Property: SampClk.ActiveEdge
Source Device: Dev2
Source Terminal: Ctr0InternalOutput
Task Name: _unnamedTask<24>
Is there any other alternative for Ctr1InternalOutput which can be used for external clock source that is routed in the card? My setup is similiar to https://decibel.ni.com/content/docs/DOC-10831
Connected Ctr0 SRC -> PFI8
Ctr0 AUX ->PFI10
Thanks.
CLD
(4,107 Views)
Ctr0InternalOutput or Ctr1InternalOutput?  The error message seems to indicate Ctr0InternalOutput.  If this isn't the issue you'll have to post your code.
Best Regards,
John Passiak
(4,081 Views)
