Multifunction DAQ
Showing results forĀ
Search instead forĀ
Did you mean:Ā
Problems in differential acquisition
(3,949 Views)
Dear Jorge,
I have read your issue regarding grounding issues within your industrial process.I would like to show you a Developer Zone article on Field Wiring and Noise Considerations which should help answer a few of your queries. Please refer to Section 3 - Measuring Floating (Nonreferenced) Sources .
The disadvantage of differential is that it halves the channel count of the device, however the measurement taken is of significant advantage as it rejects common mode noise.
I hope this helps.
Message Edited by Ashish N on 09-25-2008 07:41 AM
Ashish Naik
Automotive Business Development Manager
National Instruments UK
(3,922 Views)
Well, this solution is better than the COM, but needs aditional 10 k resistors for each differential channel. Is there a way of solving this problem without using the 10 k resistor with this scheme? An additional option, perhaps...
My best regards, Jorge Lopes
(3,871 Views)
Dear Jorge,
If you are using a floating signal source then you need resistors to provide a return path to ground for the bias current.
However if you are using a grounded signal source then there is no need for resistors.
This is explained in Table 1 of Section 3 of Table 1 of Section 3 of Field Wiring and Noise Considerations.
Ashish Naik
(3,859 Views)
