Multifunction DAQ
USB 6008 as counter
I am using USB 6008 as a counter. As I need the count to be refreshed in each count I used the daqmx create channel and and daqmx read in side the while loop. Then I am getting the error  -88708. I am using labview 7.1 and daqmx 8.0.1
Sheeja
(3,847 Views)
What type of counter? I think the only option is for Count Edges. If that is the function you are using, can you post the VI or an image of the block diagram to see why the resource is not available?
(3,846 Views)
Edge counter only. When I gave the clear task it worked. But still when the counting is too high it gets stuck.
(3,810 Views)
I am attaching the image of the VI  I created.
(3,809 Views)
