Multifunction DAQ
NI cDAQ-9174 Not recognized
Hi Mark,
Have you had the chance to update your DAQmx driver to our latest one? http://joule.ni.com/nidu/cds/view/p/id/4297/lang/en
Steps:
Unplug all NI hardware, Uninstall DAQmx, Install DAQmx and plug your device.
Let me know if this helps.
MJ
Application Engineer
Message 21 of 27
(3,233 Views)
The machine was using the most up-to-date DAQmx drivers as of the time I built the installer a couple weeks ago. The specific version is probably in the technical report I attached, but I already reinstalled Windows. I couldn't keep our client waiting any longer.
Nevertheless, as far as I know, it could happen again at any time. Please consult the technical report for more details.
Thanks.
Message 22 of 27
(3,228 Views)
Hi Mark,
At a quick glance it does seem like you were missing a few files which would be related to a corrupt install of DAQmx.
Also, to help narrow down the source, do you remember if you were able to view your NI hardware in question within window's device manager?
MJ
Message 23 of 27
(3,201 Views)
Only the chassis showed up in Windows device manager, not the modules. When it's working, the chassis and all the modules are listed.
Which files were missing that indicated corruption? If those had been replaced, would that have fixed it?
Message 24 of 27
(3,195 Views)
Hi Mark,
I did no dig far enough to see what files are missing. They could be driver files or windows registry files.
The suggested steps to solve such issues as discussed in this forum:
1. Reset Max Configuration
2. Repair DAQmx and NI-MAX install
3. Unistall DAQmx and reinstall DAQmx
Unfortunately, if the above procedures do not solve the issue, there is some sort of corruption within the Windows registry. Which would explain why reformatting solves the issue. There are no other simple steps we can take once a registry is corrupt. I apologize for any inconvenience
An alternative option might be to use a Windows tool that allows restoring your system to an earlier configuration as explained on Microsoft's website: http://windows.microsoft.com/en-us/windows7/what-is-system-restore
MJ
Message 25 of 27
(3,184 Views)
Hi all,
a slightly different issue here, but that is still relevant to this discussion.
I have Labview 19.0, with DAQmx and everything, installed exactly the same way and around the same time, on two Windows 10 laptops, one older than the other.
The chassis shows up fine and functions properly on the newer laptop.
But it does not even show up in MAX on the older one, let alone labview. Windows complains about not recognizing the device.
Any clue anyone?
Thanks for your help
Quentin
Message 26 of 27
(2,071 Views)
HOLA TENGO EL MISMO PROBLEMA QUE TODOS TENGO WINDOWS 10 Y NI 9174 NO LO RECONOCE ANTES DE TODO ESTO LO BORRÉ EN EL NIMAX Y AHORA NO APARECE AYUDA POR FAVOR
Message 27 of 27
(1,411 Views)
