Multifunction DAQ
NI cDAQ-9174 Not recognized
Hello, I'm not sure if this is the right board, but here goes.
I have a USB NI cDAQ-9174 that I am trying to use with LabVIEW 2009 and DAQmx 9.1. After I had installed LabVIEW 2009, I thought that it had DAQmx and the device drivers installed with it, so I plugged in the cDAQ. I then realized my error, and installed DAQmx from the disk that came with the cDAQ.
Unfourtunatly, the device is not recognized by SignalExpress or MAX. It shows up in Windows device manager as "cDaq-9174" under the heading "National Instruments Device", but NI Device Monitor never detected the device.
I uninstalled DAQmx then plugged in the cDAQ to no avail, then uninstalled the driver from the device manager and unistalled DAQmx again and plugged in the cDAQ, same deal. I am now uninstalling all National Instruments software in an attempt to fix this, if it doesn't work I really don't have any clue what to do.
If anyone could help out, that would be great. I am working on a HP desktop.
Message 1 of 27
(19,791 Views)
Just a follow up, un-installing all National Instruments software did not fix the issue. Plugging in the cDAQ after installing a fresh copy of LabVIEW 2009 and DAQmx 9.1 did not bring up the "Install New Hardware" dialog. I have no idea what to do, does anyone know how to get Windows to install it correctly?
Message 2 of 27
(19,785 Views)
Do you have the options of trying the chassis on a different computer?  Also, which model of HP PC are you using?
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
Message 3 of 27
(19,779 Views)
Seth,
I was able to load just DAQmx on a different computer. The device was recognized immediately and worked. I'm not sure how to fix the issue on the machine I'm trying to use it on, so I am going to reinstall Windows (it was just set up, so it's no big deal). This time I will make sure to install DAQmx from the disc before trying to plug it in. If my troubles still persist, then I'll know if it is something with the PC hardware.
Thank you,
Luke
Message 4 of 27
(19,762 Views)
I am also having a similar issue with a cDaq-9174 and Daqmx 9.1
I have tried repairing all of the NI Daqmx 9.1 installation components but MAX still does not recognize the device.  It may not be specifiecally related to the cDaq since MAX also will nto recognize my USB-6008 either.
All wokred fine last with NiDaqmx 9.0.2
Dan
For NI AEs:
William Schoettler is working on this SR:7282402
Message 5 of 27
(19,761 Views)
Accepted by topic author lukepike
Luke,
If you get this message in time, hold off on the Windows reinstall, there is one other step I'd like you to try if possible.  Follow the steps in this KB (completely deleting the Data folder in step 7): What is the Process For Removing MAX Database Corruption?
Hopefully, this will be a less painful way of addressing the issue.
Seth B.
Message 6 of 27
(19,755 Views)
Luke,
Another thing to consider is that you may have a bad entry in the Windows Registry that is not being cleared when LV is uninstalled.  This entry was probably created when you connected the cDAQ without the proper NI drivers being installed.  I have in the past as a last resort hand edited the registry to remove stuff like this.
Entry should appear under HKEY_LOCAL_MACHINE>SYSTEM>ControlSetxx>Enum>USB
P.S.  Thanks again for the robot demo the other night.
Message Edited by Wayne.C on 04-09-2010 08:48 AM
Message 7 of 27
(19,740 Views)
Seth,
Thank you for your help. We did not end up reinstalling Windows, so I tried what you suggested. Following those steps and deleting the Data folder fixed the issue.
Message 8 of 27
(19,693 Views)
I am having a similar problem and deleting the data folder did not fix the issue.
Vista 32 bit
Labview 2009
NI-DAQmx 9.1
 I have a cDAQ-9174 with 4 modules (NI9263,NI9401,NI9213,NI9201). I double checked the hardware with a different computer running XP/Labview 2009/NI-DAQmx 9.1 and it worked as it should.
On the Vista machine the cDAQ-9174 appears in windows device manager but fails to be recognized by MAX. I have uninstalled and reinstalled all the national instruments software with no change. I have deleted the data folder as suggested with no change. I am unwilling to reinstall windows to make this work (I haven't had to reinstall windows in years - I hope we're not back to that...)
Any suggestions?
Message 9 of 27
(19,561 Views)
Hello kmeloy,
First, I apologize for the inconvenience of this issue, I know it must be frustrating.  Hopefully we can resolve this without having to resort to extreme measures.  Could you post screenshots of what the devices show up as in Windows Device Manager and the Hardware IDs for the chassis and a module?  To find the hardware IDs, right click on the device and select properties, then go to the Details tab and select Hardware ID.
It will look something like this:
Seth B.
Message 10 of 27
(19,540 Views)
