Multifunction DAQ
Incorrect Binary Values.
I am having an issue with my X-Series DAQ (PXIe 6366) and LabVIEW 2009 SP1. I am trying to write my analog measurement input into a binary file, as I take that binary file and manipulate it. My concern has been that I think the DAQ is not reading in the correct binary values in order to do so. I probe the DAQmx Read output and the waveform I get is consistent with MAX, but somehow when I read in the binary file into my C++ algorithm, my results are flawed. I know that the algorithm works as it has been working for years. So, I suspect that my header file/scaling coefficients might be wrong, or that I am getting wrong binary representations of the values that I am reading in.
If anyone has any advice as to what I can do it would be much appreciated. I don't have the VIs until monday. And also, I am relatively new to labview, so simple terminology would be very nice.
Thank you in advance.
Mathew
(3,442 Views)
Accepted by topic author matt87
When you get the VIs, attach them. To many possibilities to guess.
(3,437 Views)
