Multifunction DAQ
VC++ 6 exapmle code for USB 6501
Does anyone know where I can get an example code in VC++ 6 for a simple read and write to USB 6501?
Thanks Amir
(3,845 Views)
You should probably post in this forum for VC++
http://forums.ni.com/t5/Measurement-Studio-for-VC/bd-p/231
Tim
GHSP
(3,832 Views)
If you're starting your application from scratch, I would recommend that you use the C API in C++.  For examples using the C API, you can find them linked in the start menu under Programs>>National Instruments>>NI-DAQ>>Text-Based Code Support>>DAQmx ANSI C Examples.
If you prefer to still use the C++ DAQmx API, example locations can be found referenced in this KnowledgeBase article: http://digital.ni.com/public.nsf/allkb/5616471F25B43DF48625745F004F276A.
Andy McRorie
NI R&D
(3,818 Views)
