How can I install just selected features( like just nidaq drivers) for NI-DAQ 693 via command line silently
I am trying to create installation program for my application which uses NI-DAQ drivers.
I want to include the installation of NI DAQ drivers with my program. I know that you can use setup.exe from command line. But for version 6.9.3 is there a way I can specify along with setup.exe , just the features I want to install.
I would really appreciate a prompt reply.
Thanks.
Arti
(3,348 Views)
Hello Arti,
Please see this link which explains how to do a silent installation of NI-DAQmx: http://digital.ni.com/public.nsf/websearch/CBDAA88478F7179C86256E36001BE050?OpenDocument
Also, see that document attached below for instructions on how to do a silent installation of NI-DAQ 6.9.x.
Bill B
Applications Engineer
(3,348 Views)
Dear Bill,
Thank you for taking out time to respond to my question. unfortunately it still doesn't solve my problem.
the link you sent talks about NI-DAQ 7.2 and I am working with ni-daq 6.9.3 and I am not sure how to create that specific file. I would really appreciate if you can direct me on how to create it. as that perticuler file contains version no for various other components and I am not sure what there counterpart would be for 6.9.3.
Text file which you sent me, again is for 6.9.0 as it talks about nidaq.exe with ADDLocaL option, and a cabs folder, which are all not present in 6.9.3.
I would really appreciate you helping me out on this issue.
Arti
(3,348 Views)
Arti,
You may find this document to be more helpful:
http://zone.ni.com/devzone/conceptd.nsf/2d17d611efb58b22862567a9006ffe76/9530f9276f4ae078862568c00074a92a?OpenDocument
Bill
(3,348 Views)
Well thats all the info I had gathered from NI's website already.. This DOES NOT apply to me.
as ni-daq 6.9.3 has no nidaq.exe file, it has a setup.exe which does not support the commandline parameters for slient installation of selected feature.
I would really appreciate someone looking into this problem seriously.
Arti
(3,348 Views)
