‎03-08-2021 08:33 AM
I'm currently using a myRIO and need a DAQ device that has more inputs and outputs compared to the myRIO. Could you please suggest me any DAQ devices?
‎03-08-2021 08:45 AM
Could someone suggest me if there is a DAQ device similar to the myRIO that has 12 analog inputs and 12 analog outputs. Does that type of device actually exist? When I was searching online, I was able to find devices that that had 8 analog inputs.
Kindly Request your suggestions.
‎03-08-2021 09:06 AM
12 AI and 12 AO will be hard to find. Are you still trying to use the myRIO or do you want PC control? What kind of budget do you have?
‎03-08-2021 11:09 AM
We will also be using a myRIO. The budge is between 1000 to 3000 dollars I guess.
‎03-08-2021 10:51 PM
If you could spend more, you could look at cDAQ series with two modules (1 for AO and 1 for AI). There are some cDAQ modules with 16 channel of AO or AI.
‎03-09-2021 07:58 AM
Or to be more similar to a myRIO, use a cRIO using the same C-series modules.
