Convert ni-daq to ni-daqmx
I am tring to convert a NI-DAQ vi. to NI-DAQmx.  I have tried but have failed as I can't seem to get it to work.  If anyone is looking for something to do maybe you could help me out in the conversion.  I have attached the original vi.
Azazal
Azazel
Pentium 4, 3.6GHz, 2 GB Ram, Labview 8.5, Windows XP, PXI-5122, PCI-6259, PCI-6115
(2,936 Views)
Hi Azazal,
There is no need to convert your particular vi. If you have loaded the DAQmx driver, this will also load DAQmx examples with it. Take a look  at  Acq&Graph Voltage - Int Clk - Dig Start.vi (or ContAcq&Graph Voltage - Ext Clk - Dig Start.vi for continous aquisition) and modify to suit.
Hope this helps
(2,925 Views)
