Multifunction DAQ
Base address problem
First off I need to preface by saying I know little to nothing about this stuff, however we use an NI card for side-scan sonar data acquisition using Chesapeake Technologies.
We use a PCI-DIO32HS card that was installed and running fine in an onlder Pentium III computer.  I was in the process of bringing the software and cards into a new Dell system, however some connections I had ordered hadn't arrived, so I was attempting to reinstall the card into the PIII computer and now it wont recognize the base address in either computer.  I have tried deleting the device in Measurements and Automation, shutting down, removing the card, rebooting, and adding the card again.  I have tried the same technique in addition to uninstalling and reinstalling the newest driver for the card (7.4.1) downloaded from the net last night.
Summary:
Basic problem:
Installing (again) the card I get the same error under test resources "Device is not responded to the selected base address"
HELP!!!
(3,356 Views)
Hello Bryan,
I would recommend removing the card, uninstalling the DAQ driver, downloading a fresh version from the internet one more time and installing this new version, reinserting the card and trying one last time.  If that doesn't work, I would recommend contacting support.
Micaela N
(3,337 Views)
